简介
This guide will teach you how to access, remove, and replace your iRobot Roomba 692 motherboard. If you are replacing the motherboard, ensure that you have the right motherboard for the Roomba 692 prior to removal.
Remember to review the iRobot Roomba 692 Troubleshooting Page before attempting any maintenance or repairs on your vacuum.
你所需要的
To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
Remove the ten 13.3 mm screws with a Phillips #00 screwdriver.
Pull off the outer and inner holders.
