跳转到主内容
iPod Touch 4th Generation Upper Logic Board Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPod Touch 4th Generation Upper Logic Board Replacement, Upper Logic Board: 步骤 1 中的图像 1,1
    • Remove the following three screws near the top edge of the logic board:
    • One 2.0 mm Phillips screw
    • Two 2.3 mm Phillips screws
  2. iPod Touch 4th Generation Upper Logic Board Replacement: 步骤 2 中的图像 1,1
    • Use the edge of an iPod opening tool to gently pry, but not remove, the rear-facing camera away from the rear case.
    • Do not attempt to remove the rear-facing camera yet.
  3. iPod Touch 4th Generation Upper Logic Board Replacement: 步骤 3 中的图像 1,2 iPod Touch 4th Generation Upper Logic Board Replacement: 步骤 3 中的图像 2,2
    • Use an iPod opening tool to slightly lift the edge of the logic board next to the battery enough to grab it with your other hand.
    • Do not excessively bend the logic board, as it is very thin and fragile.
    • Be very careful not to lift too much as the volume control ribbon cable is still connected and will tear very easily.
    • While gently lifting the logic board with one hand, use an iPod opening tool to lift the logic board near the copper tape at the logic board's top edge.
    • The logic board will be lifted adequately when the last display assembly connector has cleared the top edge of the rear case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 13
总计 4,290
