跳转到主内容
加入维修社区 - 创建账户
iPod Shuffle 4th Generation Control Button Cover Replacement
你所需要的
    1. iPod Shuffle 4th Generation Control Button Cover Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
      • Before proceeding, be sure your Shuffle is switched off.
      询问修复机器人
      添加评论
      • Use a heat gun, hairdryer, iOpener, etc. to heat the back of the Shuffle until it's slightly too hot to the touch.
      • If using a heat gun, only apply heat for a few seconds at a time. Check the temperature of the metal - if it gets too hot to handle, let it cool.
      询问修复机器人
      添加评论
    2. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 3 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 3 中的图像 2,2
      • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
      • There are no clips on the top and bottom of the rear panel. With the Apple logo upright and facing you, all the clips are to the left and right.
      • If you use a metal spudger, you will scratch the housing.
      • You can try to pull on the rear panel by the clip. If you use too much force, you will bend the rear panel. If it feels stuck, stop and heat the glue to soften it.
      添加评论
    3. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 4 中的图像 1,1
      • Remove the rear panel from the Shuffle.
      • There may be a piece of black rubber covering the logic board, or it may come out with the rear panel. This piece is part of a rubber seal that goes around the edges of the rear panel and covers the controls from the inside.
      询问修复机器人
      添加评论
    1. iPod Shuffle 4th Generation Control Button Cover Replacement, Logic Board Assembly: 步骤 5 中的图像 1,1
      • If present, remove the thin black moisture seal covering the Shuffle's internals.
      • Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
      询问修复机器人
      添加评论
    2. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 6 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
      添加评论
    3. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 7 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 7 中的图像 2,2
      • Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
      • Lift the battery out of the front case, being sure not to strain its delicate leads.
      添加评论
    4. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 8 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 8 中的图像 2,2
      • Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
      • Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
      • Remove the logic board retainer from the Shuffle.
      询问修复机器人
      添加评论
    5. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 9 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 9 中的图像 2,2
      • Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
      询问修复机器人
      添加评论
    6. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 10 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 10 中的图像 2,2
      • Continue pushing the logic board down away from the top edge of the Shuffle.
      • Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
      • Remove the logic board assembly from the Shuffle.
      询问修复机器人
      添加评论
    1. iPod Shuffle 4th Generation Control Button Cover Replacement, Control Buttons: 步骤 11 中的图像 1,1
      • Remove the following four screws:
      • Two 1.2 mm Phillips screws with large heads.
      • Two 1.6 mm Phillips screws with small heads.
      询问修复机器人
      添加评论
    2. iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 12 中的图像 1,2 iPod Shuffle 4th Generation Control Button Cover Replacement: 步骤 12 中的图像 2,2
      • Use an iPod opening tool to pull the control button plate out of the front case.
      • Remove the control buttons from the Shuffle.
      询问修复机器人
      添加评论
    1. iPod Shuffle 4th Generation Control Button Cover Replacement, Control Button Cover: 步骤 13 中的图像 1,1
      • Push the rubber control button cover out of the front case.
      • When reinstalling the control button cover, be sure it is properly aligned and that its top and bottom edges are seated in the grooves cut into the front case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
2指南评论
Great job my friend
Diego da Silva Ferreira - 回复 分享
Hola, quisiera saber donde poder localizar las piezas de repuesto de la botonera play/pause tanto la pieza electrónica como la botonera. Gracias
Verónica - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 76
总计 10,178
