当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
加热iOpener三十秒
在整个维修过程中,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
如果iOpener过热膨胀,千万不要触碰iOpener。
如果iOpener中间部分依然烫的没法碰,请等待冷却后再使用,加热好的iOpener 应该可以保持热度十分钟
如果你没有微波炉,请按照此步骤在沸水中加热iOpener。
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
iOpener会很燙,所以拿取時請小心的從iOpener的邊邊拿
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
Insert a spudger under the cover, then pry it up and away from the device.
Remove the rear plastic cover from the iPod.
Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
The adhesive under the metal midframe/display assembly is quite strong and the components are fragile, so go slowly and gently. Make sure you do not bend the LCD screen.
Pull the front panel assembly slightly down and partially out of the device.
You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
Do not separate the two halves entirely, they are still connected by several cables.
Gently unfold the two halves of the device to access the internal components.
Do not try to completely separate the two sections, yet, as they are still attached via a soldered cable.
Insert a spudger under the metal midframe and display on the left side of the home button.
Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
Rotate the spudger around the home button and across the front panel, releasing the adhesive holding the display in place.
Use the flat end of a spudger to push the home button gasket toward the center of the button to release the light adhesive.
Work your way around the home button in this manner until you can easily remove the button from the front glass.
To prevent tearing the gasket around the home button, do not pry the home button out until the adhesive has been sufficiently loosened.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
