跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Front Camera Assembly Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Front Camera Assembly Removal, Prepare the phone for disassembly: 步骤 1 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Removal, Prepare the phone for disassembly: 步骤 1 中的图像 2,2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Front Camera Assembly Removal, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Removal, Tape over any cracks: 步骤 2 中的图像 2,2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Front Camera Assembly Removal, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Removal, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Removal, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Front Camera Assembly Removal, Remove the pentalobe screws: 步骤 4 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Removal, Remove the pentalobe screws: 步骤 4 中的图像 2,2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Front Camera Assembly Removal, Disconnect the earpiece speaker: 步骤 5 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Removal, Disconnect the earpiece speaker: 步骤 5 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Removal, Disconnect the earpiece speaker: 步骤 5 中的图像 3,3
    • The 5G mmWave antenna is only in United States and Puerto Rico iPhone 16 Pros (model A3083). For all other models, skip the next four steps.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
  6. iPhone 16 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: 步骤 6 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: 步骤 6 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: 步骤 6 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the two front camera assembly press connectors underneath the previous two.
  7. iPhone 16 Pro Front Camera Assembly Removal, Remove the front camera assembly: 步骤 7 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Removal, Remove the front camera assembly: 步骤 7 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Removal, Remove the front camera assembly: 步骤 7 中的图像 3,3
    • Use a spudger or your fingers to pick up the front camera assembly and remove it from the phone.
结论
To reassemble your iPhone, follow this guide in reverse order.
After your repair, calibrate a genuine replacement front camera assembly using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
Nick Schultz
于03/24/24注册
44,147 声望
创作了254篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,065篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 64
