跳转到主内容
iPhone 12 五角螺丝更换
你所需要的
  1. iPhone 12  五角螺丝更换, 移除五角螺丝: 步骤 1 中的图像 1,1
    • 注意:开始之前,请为iPhone电池放电25%以下的电量。如果意外刺穿,已充电的锂离子电池可能着火和/或爆炸。
    • 开始拆卸前,请关闭iPhone的电源。
    • 卸下iPhone底部边缘的两颗6.7毫米长的五角螺丝。
    • 打开iPhone的显示屏将损害其防水密封性。在执行此步骤之前,请准备好备用密封条,或者如果在不更换密封条的情况下重新组装iPhone,请小心避免液体暴露。
    Do you sell the waterproof seals separately or are they included in the kit?
    Heather Furnas - 回复
    Do you sell the waterproof seals separately or are they included in the kit? (I would like to know this as well.)
    CaliforniaGunner - 回复
    I just got my Fix Kit and it includes the seals. Not sure if a "part only" version would, though.
    Neal Sofge - 回复
结论
要重新组装设备,请按照逆序进行操作。
9等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Adam O'Camb
于04/11/15注册
208,958 声望
创作了416篇指南
4条评论
This is perfect, thank you! I wasn’t sure I’d be able to do this repair, but with this expert guidance I have succeeded. I’m ready for level 3.
Chris Phelan - 回复
well done - would you like medal
Repairify Scotland -
someone just pointed out the fact it says to discharge the battery -
‘Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. ‘
you are removing the 2 pentalobes, not anything ‘internal’
Repairify Scotland - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 97
过去 30 天: 286
总计 11,795
