跳转到主内容
加入维修社区 - 创建账户
iPad Pro 12.9" 3rd Gen Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. iPad Pro 12.9" 3rd Gen Screen Replacement, Screen Replacement: 步骤 1 中的图像 1,1
    • iPad Pro 3rd Gen' A1895
    • Be sure to turn off the iPad by pressing and releasing the volume up button then volume down.
    • Press and hold the side button until the screen turns off.
    • Use the slider if you can.
    • Not powering it off can blow out your LCD back light just like iPhones other iPads!
  2. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 2 中的图像 1,1
    • You can use a heat gun or another handy heating method! MUST DO!
    • Heating the entire screen will help make it easy to safely remove the screen.
  3. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 3 中的图像 1,1
    • Leave it on the heat for 15 minutes to loosen the strong adhesive.
    • Use an ifixit suction cup to pull up the screen so that you can insert a plastic pick.
  4. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 3,3
    • Apply tape or adhesive over broken glass!
    • Bust out the metal pry tool lifting broken causing glass to stick to tape working your way around broken side.
    • Wiggle Jiggle the screen off the adhesive using multiple plastic guitar picks.
    • Do Not Tear the Screen Off!!!
  5. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 3,3
    • Do not rip the screen off!! Cables are very short will cause internal Damages!!!
    • On the Top of the screen the proximity sensor front camera has to be disconnected 1st.
  6. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 6 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 6 中的图像 2,2
    • Lay screen flat pull it down just enough to use a PH000 Screw drive to remove the safety bracket
    • Use Flat Ended Spoudger remove the bracken and cable from the Logic board!
  7. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 7 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 7 中的图像 2,2
    • Perfect! Now Lift the screen folding it up to the left like so!
    • Remove 5 PH000 Screws protecting Power Connection and Display Cables
  8. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 3,3
    • Remove PH000 Battery Connection clip retaining screw.
    • Do not attempt to remove battery connection.
    • Move Small cable is taped around edges up so you can gain access to the side of the battery connection.
    • Slide thin plastic under battery connection. This will lift the battery connection pins away from the battery cable connectors and isolate the battery.
    • After Isolating battery.
    • Remove all 3 ribbon cables from logic board with flat headed spudger!
  9. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 3,3
    • Just a touch of heat don't melt the thing off remove the face ID sensor from Old Screen.
    • Damaging Proximity sensor could effect True Tone with 3rd Party Parts
    • Gently use a tool to get under glued down connection on glass frame of screen!
  10. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 3,3
    • Remove Bracket off old screen you and move it to new screen
    • Transfer Cables and Bracket to new screen
  11. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 3,3
    • Place Screen without adhesive test your screen and face ID
    • After running test take
  12. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 12 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 12 中的图像 2,2
    • Clean Edges with flat ended metal tool to remove broken glass
    • Clean desk of glass on table get ready to remove Proximity sensor from old screen!
    • Do not clamp recommend to use flat and heavy object
    • Broken glass on the frame will crack your new screen
结论
Mark D Schlossman
于09/25/19注册
7,176 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 99
