跳转到主内容
iPad 6 Wi-Fi Front Panel Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 步骤 1 中的图像 1,2 iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 步骤 1 中的图像 2,2
    • Remove any tape covering the home button ribbon cable connector.
  2. iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 2 中的图像 1,3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 2 中的图像 2,3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 2 中的图像 3,3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  3. iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 3 中的图像 1,3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 3 中的图像 2,3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 3 中的图像 3,3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  4. iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 4 中的图像 1,2 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 4 中的图像 2,2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  5. iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 5 中的图像 1,2 iPad 6 Wi-Fi Front Panel Assembly Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
结论
另外一个人完成了本指南。
Sam Goldheart
于10/18/12注册
471,504 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,429篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 7
总计 162
