简介
Use this guide to replace your iPad 3G's communications board which is responsible for sending/receiving 3G data.
你所需要的
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Use the edge of an iPod opening tool to carefully pry the remaining antenna connector up off the communications board.
11等其他人完成本指南。
