跳转到主内容
iPad 2 CDMA Headphone Jack Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: 步骤 1 中的图像 1,3 iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: 步骤 1 中的图像 2,3 iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: 步骤 1 中的图像 3,3
    • Use the flat end of a plastic opening tool to flip up the retaining flap on the headphone jack and front-facing camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Run a plastic opening tool underneath the headphone jack and front-facing camera cable to free it from the adhesive attaching the cable to the rear panel.
    • Pull the headphone jack and front-facing camera ribbon cable straight out of its socket on the logic board.
  2. iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the rear panel.
  3. iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to help pull the headphone jack away from its recess in the top edge of the iPad.
    • Don't try to remove the assembly just yet.
  4. iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 4 中的图像 1,1
    • Carefully peel the front camera and microphone cables off the rear panel.
  5. iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 5 中的图像 1,2 iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use the edge of a plastic opening tool to disconnect the front camera cable from the headphone jack cable.
  6. iPad 2 CDMA Headphone Jack Assembly Replacement: 步骤 6 中的图像 1,1
    • Carefully peel the front camera cable off the bottom ribbon cable attached to the headphone jack.
结论
Phillip Takahashi
于08/22/11注册
87,319 声望
创作了87篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 437
