跳转到主内容
iMac Whiteboard
你所需要的
  1. iMac Whiteboard, iMac Whiteboard: 步骤 1 中的图像 1,1
    • We start up with an empty case of an iMac.
    • For directions on removing all of the interior components from your iMac, check out the 24" iMac EMC 2111 device page.
    • This procedure should also work on an iMac G5 or early Intel iMac.
  2. iMac Whiteboard: 步骤 2 中的图像 1,1
    • Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
  3. iMac Whiteboard: 步骤 3 中的图像 1,1
    • Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
  4. iMac Whiteboard: 步骤 4 中的图像 1,1
    • Place the whiteboard onto the front case and put weight on it.
    • Make sure that the whiteboard touches the lower side of the metal panel.
    • Leave to dry out for a day.
  5. iMac Whiteboard: 步骤 5 中的图像 1,2 iMac Whiteboard: 步骤 5 中的图像 2,2
    • Mark up 4 lines of 4cm each on the cardboard.
    • Cut up a rectangle and fold to make up a cylinder. Use scotch tape to hold them together.
    • Repeat to get 2 more cylinders.
  6. iMac Whiteboard: 步骤 6 中的图像 1,1
    • Glue the cylinders to the back case of the iMac.
    • This is to have some pressure against the whiteboard.
  7. iMac Whiteboard: 步骤 7 中的图像 1,1
    • After the contact cement has dried, take out the small contact cement remnants from the board with a box cutter and a plastic tool (as to not damage the whiteboard)
  8. iMac Whiteboard: 步骤 8 中的图像 1,1
    • Reassemble your iMac and write something on it.
结论
Very useful mobile whiteboard!
2等其他人完成本指南。
Angela Penaherrera
于05/06/13注册
12,574 声望
创作了5篇指南
4条评论
Great idea! How about adding an attachment to the bottom of the stand to hold a book open. Maybe use the speaker case cut to size. Affix it using the holes for the RAM access plate.
mayer - 回复
Thats a great idea too! If you add the stand post some pics ^_^
Angela Penaherrera -
Angela, I tried contacting you via twitter, would you click on my icon and email me. This is about my possible relocation to Ecuador .
mayer - 回复
Done! Check your inbox :)
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 26
总计 8,131
