简介
Use this guide to remove the CPU heat sink.
你所需要的
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
Peel the tape away from the lower corner of the right speaker.
Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
Use the tip of a spudger to push the CPU thermal sensor cable connector out of its socket on the logic board.
3等其他人完成本指南。
一条评论
Hi Andrew
How tight do you tighten the screws when refitting the heatsink, as the screw bosses are spring loaded
