跳转到主内容
iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement
你所需要的
  1. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Display: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 21.5" Cardboard Service Wedge
    购买
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    I have (21.5 inch, mid 2017, 2.3 ghz) base model same as this but not 4k. How much max ram can I install in my iMac??
    Narendra Verma - 回复
    This guide contains many extra steps for what should be a straight forward, simple parts replacement without disturbing more than the display, left hand speaker and removal of 4 logic board screws for play. Nothing else except for the left hand speaker wire & iSight cable from logic board, the lower support bracket and loosening the speaker so as to move it around a bit.
    For the ram, I bent a pair of cheap tweezers long ago supplied with these replacement kits to the perfect angle for holding, locating and inserting the ram into the slots under the logic bd after moving each retainer w/spudger and popping out the old. Pay attention to the orientation of the ram when removing/inserting the ram! An automotive mirror is handy along with a small flashlight for closeups. Once the ram is aligned properly substitute your fingers for the tweezers, ease it into the slot, push up & engage! Reinstall screws and all else. I have done this job successfully this way countless times. For a tweezers pic contact me!
    Ross Elkins - 回复
    Additionally, if a blade is present, I install the OSx system on the blade and everything else, apps and home folders on the new SSD. You get the very fast boot off of the blade and the full ssd for all else!
    Ross Elkins - 回复
  2. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 2 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 2 中的图像 2,2
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Be gentle! The glass may crack if pried too much. Use a hairdryer to heat the edges and loosen the tape if the room temperatures are low.
    Always use a hairdryer!! I cracked my glass
    8bit !!! - 回复
  3. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 3 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 3 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 3 中的图像 3,3
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 4 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 4 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 4 中的图像 3,3
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 5 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 5 中的图像 2,2
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 2,2
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 7 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 7 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 7 中的图像 3,3
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 8 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 8 中的图像 2,2
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 9 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 9 中的图像 2,2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 10 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 10 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
    Don't forget to place the mac face up on the table. Unlike older models, there is no more flap at the bottom holding the display in place. If you do these steps with the Mac upright, the screen will pop out, hit your table, and shatter :( Don't ask me how I know.
    John M - 回复
    So sorry. Thanks for that caution.
    Ted Horodynsky - 回复
    Using suction cups (the ones that were made for removing the magnetic front glass on the 2011 and earlier iMacs) work well too. Place one in each top corner, while the Mac is lying face up on a table, and gently pull and it will separate the display from the main body. You might need to do a little more slicing around the edges if you did not get all the way through the first time with the roller. Then you can lift the display up at an angle to disconnect the cables.
    Peter Hillman - 回复
    This was a great idea, worked well for me. Thanks!
    Florin -
  11. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 11 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 11 中的图像 2,2
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 12 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 12 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 12 中的图像 3,3
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 13 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 13 中的图像 2,2
    • Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 14 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 14 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 14 中的图像 3,3
    • Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac.
  15. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 15 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 15 中的图像 2,2
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 16 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 16 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 16 中的图像 3,3
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 17 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 17 中的图像 2,2
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 18 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 18 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 18 中的图像 3,3
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
    Ne forcez surtout pas et soulevez l’écran par les deux extrémités ! Il faut que tous les adhésifs soient bien découpés pour que l’écran se dégage du boitier sans effort. Toute torsion de l’écran peut entraîner une superbe fissure sur le verre :-/
    mf - 回复
  19. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 19 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 19 中的图像 2,2
    • While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    As seen in photo:
    bottom cable pulls up
    top cable cable pulls right, after safety clip opened
    airshack - 回复
  20. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 20 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 20 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 20 中的图像 3,3
    • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  21. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 21 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 21 中的图像 2,2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    There are pull tabs at each side off the bottom edge to allow easy release of the tape
    DarrenG - 回复
    DarrenG’s observation about the pull tabs saved me a ton of time trying to pry the display as per the original instructions. Thanks!
    lesfam5 - 回复
  22. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 22 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 22 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 22 中的图像 3,3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
    The roller tool for slicing open the display works great for this step. Get in there like using the card and roll across the bottom to slice through the remaining adhesive.
    Peter Hillman - 回复
  23. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 23 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 23 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 23 中的图像 3,3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • During reassembly, head over to our display adhesive guide to install the new adhesive.
    After removing the display, I also removed the 3 screws for the processor fan, disconnected the power connector for it and set the fan shroud aside. Disconnecting the remaining cable (similar style to 1 of the cables for the display) that is in the way of the RAM chips is all that's left to do. I was then able to access and quickly remove the two Apple-provided RAM chips, and replace them with 3rd party RAM. Turning the iMac on its side, so that it's in a position where you're physically putting the RAM chips DOWNWARD into their respective slots is the best way to go about uninstalling and reinstalling the chips. Using a narrow but long'ish plastic spudger tool is the best way to defeat the spring-tabs which hold the RAM chips in place. After removing the LCD display, changing the RAM is about a 10 minute process!! And I'd SURE prefer not to remove all the parts and risk damage to the iMac via the standard procedure listed. As per usual, take your time and work gently :-)
    Mitch K - 回复
    Teardown the whole machine just to change RAM? While preparing to comment on this procedure I just noticed the comment made by Mitch K above. I ran pretty much the same procedure that he describes this afternoon (steps 1-23, 43-45, and step 55). Then I swapped out the original 2x4GB RAM chips for 2x8GB chips by reaching behind the logic board, releasing the spring retaining clips one chip at a time (starting with the chip further away from the logic board), pivoting the RAM towards the back of the machine, and then carefully sliding it out of the slot. I easily slid in the new chips and then pivoted them to lock them down. No hassle, no time lost. As Mitch K states above, not only is this “shortcut” method much quicker and easier, but it provides less risk of damaging cables, sockets and other delicate components during a total teardown. Why mess with the power supply board just to change RAM? I do not advise to follow the current iFixit.com procedure written by Sam Lionheart, regardless of user skill-level.
    nycsandor - 回复
    THAT sounds one !&&* of a lot easier than the full tear down. I wonder if there’s a video of the process described by Mitch K? Adding that to these verbal instructions would really help relieve the apprehension and anxiety around the process! I do sometimes find the additional warnings, though appreciated from a “safety first” perspective, are somewhat overstated. It’s been a very long time since I shorted out RAM, or fried a PCB, or broke a connector, regardless of how finicky, fragile or awkwardly designed and positioned. I may have WANTED to break something, and the air might be blue for a few seconds, but inevitably, things go back together, the start button gets pressed, the startup chime sounds, and we’re in business. Practice DOES make as close to perfect we are likely to get.
    bruce - 回复
    Mitch has the exact method that works a treat. You don’t need to follow steps 24-37 and also 40-63. Step 51 is the step to remove the camera cable and is needed. Steps 38 and 39 are for the Fan. That is all that is needed. Done quite a few like this.
    Be careful not to drop the RAM down the back of the logic board!
    By NOT removing all the other stuff you can avoid either damaging it or forgetting to plug in a cable.
    Charlie Nancarrow - 回复
    I just trued this shortcut and it was not successful. I was not able to seat both RAM chips with this shortcut, and managed to slightly damage one of the retainer clips. I simply could not manipulate the chips into and out of the slots effectively without taking everything apart as described in the full set of steps.. I ended up retracing my steps and following the entire procedure, carefully, and that worked without incident. So, bottomline, it is definitely more work to follow all the steps but from my experience, it is decidedly safer. Your mileage may, of course, vary. It was successful in the end, and I swapped out the hard drive with an ssd during the same procedure and my machine is very, very much faster.
    jan - 回复
    I have completed by following the Mitch K post and it is much easier than stripping down the whole thing, just be aware that to remove and replace the ram chips means working in a tight space, you need slim fingers and don’t be tempted to use force, take your time.
    Barrie Price - 回复
    Well, I have slim fingers, but they are 60 years old, and they don’t work like they used to! LOL.
    Jan Hogle -
    Agree with Mitch K’s procedure. The only added tip I would throw in is to use two 45 degree tweezers with their plastic covers still installed to easily pop loose the RAM. I couldn’t get the plastic spudger tool to work myself, but the tweezers easily reach the RAM clips. Just make sure the plastic covers are installed and you won’t be in danger of scratching or shorting anything out.
    charlesnick - 回复
    So thankful I discovered these comments. Saved me a TON of time! Thank you!!
    Adam Roberts - 回复
    These comments were very useful. Thank you. I just needed to modify a pair of tweezers to allow me to seat the new RAM more easily. The ifixit screwdriver wasn't able to turn some of the screws as they were installed too tightly, and I didn't want to wait to order and reveive a pair of right angled Torx screwdrivers that would give me more leverage to get those boards off.
    Upgrader - 回复
  24. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Right Speaker: 步骤 24 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Right Speaker: 步骤 24 中的图像 2,2
    • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
    • It is useful to push downward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    • Pull the connector downwards to remove it from its socket.
    I highly recommend doing steps 27 and 28 first and then pull out the cable. It will give you more room on the right side of the cable to work with making this step that much easier.
    Eddie de la Rosa - 回复
    The two corners of the connector are latches that need to be pushed toward the center of the connector to release. This is easily done with the pointed end of the spudger. Once the two corner latches are released, the connector comes apart easily.
    Fred Heineman - 回复
  25. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 25 中的图像 1,1
    • Remove the two 10.0 mm T10 screws securing the right speaker to the rear enclosure.
  26. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 26 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 26 中的图像 2,2
    • Pull the top of the right speaker away from the rear enclosure, about half an inch, to expose the antenna cable running down its right side.
  27. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 27 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 27 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 27 中的图像 3,3
    • Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side.
    • Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
  28. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 28 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 28 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 28 中的图像 3,3
    • Pull the right speaker straight up about an inch, toward the top of the iMac.
    • Lift the right speaker straight up and remove it from the iMac. This may take some force, both hands and rocking the speaker right and left to get it out.
    Th HP is VERY HARD to take off in this thin place
    bruno - 回复
  29. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Hard Drive Brackets: 步骤 29 中的图像 1,1
    • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
    Pay attention to this photo and where the fan is. It is 180° from where the previous step shows it is oriented to you.
    Max Romano - 回复
  30. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 30 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 30 中的图像 2,2
    • Remove the left and right hard drive brackets from the iMac.
  31. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Power Supply: 步骤 31 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Power Supply: 步骤 31 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Power Supply: 步骤 31 中的图像 3,3
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
    • Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket.
    Accomplished with spudger on top and thumbnail on bottom. Otherwise couldn’t rock it loose.
    airshack - 回复
  32. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 32 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 32 中的图像 2,2
    • Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket.
    Doing this with spudger on right and thumbnail on left seemed easier and safer.
    airshack - 回复
  33. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 33 中的图像 1,1
    • Remove the two 7.2 mm T10 screws securing the power supply to the rear enclosure.
    What if these are too tight to remove?
    Rafael Garcia - 回复
    Hi Rafael,
    Be very careful not to strip these screws. Use a new, accurate T10 bit and a driver with good leverage to loosen these screws.
    Arthur Shi -
    They are T9 in my iMac
    Glenn Koslowsky - 回复
    They were T8 screws on my machine.
    Ed Beachwood - 回复
  34. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 34 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 34 中的图像 2,2
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Tilt the power supply forward.
  35. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 35 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 35 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 35 中的图像 3,3
    • Pull the power supply slightly up and out from the rear enclosure.
    • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  36. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 36 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 36 中的图像 2,2
    • Slide the power supply to the right to clear the screw posts on the rear enclosure.
  37. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 37 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 37 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 37 中的图像 3,3
    • Rock the power supply forward and remove it from its recess in the rear enclosure.
    • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  38. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 38 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 38 中的图像 2,2
    • Flip the top of the power supply towards you to access the DC power cable connection behind the logic board.
    • Squeeze the DC power cable connector tab and pull it straight out of its socket on the back of the logic board.
    what happens if you damage the power socket on the logic board?
    Racheal Major - 回复
    The tab is on the bottom of the connector. You can’t see it. Squeeze the bottom of the connector close to the cables to properly release tab. Pulling straight out is important.
    This step might be easier if you do the next step first (step 41) and then come back to this step.
    I loosened the logic board attached to the power supply board. I then could easily remove the 2 power cables.
    Gerard Stoffels - 回复
    A photo of the disconnected power connector would be helpful in seeing how the tab release works here.
    airshack - 回复
    In the photo above, the index finger is shown squeezing the connector locking tab. Do this while using the flat end of a spudger to release the latch. Once the connector is moved about an eigth of an inch the latch is released and the connector should come out freely.
    Fred Heineman - 回复
    The photo you added is of the wrong side of the power cable connector? Please add a photo of the rear facing side so the clip mechanism so disconnection can be clearly understood.
    airshack - 回复
    The key is to squeeze the tab in the part near the cables. You won’t feel like the tab is moving, but squeezing it there is necessary to get it out.
    Adrià - 回复
  39. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 39 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 39 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 39 中的图像 3,3
    • You may find it helpful to set the iMac down on its back on the table for the next couple of steps.
    • Use the flat end of a spudger to push the clip on the side of the AC inlet cable connector inward.
    • While holding on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  40. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 40 中的图像 1,1
    • Remove the power supply from the iMac.
  41. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Fan: 步骤 41 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Fan: 步骤 41 中的图像 2,2
    • Gently pull the fan cable connector straight away from its socket on the logic board.
    I don’t like to pull on wires as shown in the photos above. I used my index fingernail on the top corner of the connector and the pointed end of a spudger on the bottom corner to pull the connector straight out of its socket.
    Fred Heineman - 回复
  42. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 42 中的图像 1,1
    • Remove the three 12.3 mm T10 shoulder screws securing the fan to the rear enclosure.
  43. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 43 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 43 中的图像 2,2
    • Remove the fan from the iMac.
  44. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Hard Drive: 步骤 44 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Hard Drive: 步骤 44 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Hard Drive: 步骤 44 中的图像 3,3
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
  45. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 45 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 45 中的图像 2,2
    • Disconnect the SATA power cable.
  46. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 46 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 46 中的图像 2,2
    • Unplug the SATA data cable from the hard drive.
  47. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 47 中的图像 1,1
    • Remove the hard drive from the iMac.
  48. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Hard Drive Tray: 步骤 48 中的图像 1,1
    • Remove the single 7.2 mm T10 screw securing the hard drive tray to the rear enclosure.
    2017 imac EMC 3069 this is a T9
  49. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 49 中的图像 1,1
    • Remove the hard drive tray from the rear enclosure.
    Cables are routed through the backside of the tray. Take a picture for reassembly.
    Mitchell Scheffler - 回复
  50. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Logic Board Assembly: 步骤 50 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, Logic Board Assembly: 步骤 50 中的图像 2,2
    • Push on each side of the left speaker cable connector with the tip of a spudger and gently "walk" it out of its socket.
    As noted in the right speaker cable section, the two corners of the connector are latches that need to be pushed toward the center of the connector to release. This is easily done with the pointed end of the spudger. Once the two corner latches are released, the connector comes apart easily.
    Fred Heineman - 回复
  51. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 51 中的图像 1,2 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 51 中的图像 2,2
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  52. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 52 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 52 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 52 中的图像 3,3
    • In a similar fashion as the previous step, de-route the SATA data and power cables up out of the retaining clip.
  53. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 53 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 53 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 53 中的图像 3,3
    • Use the flat edge of a spudger to flip up the metal retaining bracket on the iSight camera cable connector.
    • Pull the iSight camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
    As seen in the photo this clip clearly has a pull tab. Forget the spudger and just open the clip with the pull tab.
    airshack - 回复
  54. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 54 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 54 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 54 中的图像 3,3
    • Use the flat edge of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables.
    I broke off one of the antenna connectors when I took off the antenna wires, but the new 802.11ac card is working:) I seems the way to take off the wires is lifting it up from the wire side. In hindsight I just wasn´t careful enough.
    Runar Vaernes - 回复
    how do I check a working logic board
    Navneet Garg - 回复
    I labeled mine with label printer labels prior to disconnection.
    airshack - 回复
    I labeled mine with label printer labels prior to disconnection. The label/tabs made reinstalling easier as I held onto the label/tabs while pressing down on the connectors. Much easier than holding onto the physical wires.
    airshack - 回复
    If you have a pair of angled tweezers, they work well for grabbing under the connector so that you aren’t pulling on the wire. The head of the T10 screwdriver works well for pressing them back on.
    iMac 2017 EMC 3069 this has the antenna brackets with two T5
  55. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 55 中的图像 1,1
    • If brackets secure the four antenna cables, remove the two T5 Torx screws from the brackets.
  56. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 56 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 56 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 56 中的图像 3,3
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
    Unlike the rest of the connectors on the logic board, this one lifts up away from the board rather than to the side. That “Push the cable slightly to the right.” notation is after the connector is free.
    Fred Heineman - 回复
  57. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 57 中的图像 1,1
    • Remove the following screws securing the exhaust duct to the rear enclosure:
    • Two 6.3 mm T8 screws
    • Two 4.7 mm T8 screws
    Weirdly, these screws didn’t work with my T8 driver. Not with T6 or T10.
    Every other screw (to this point) has been fine. Hmm.
    Jake Lodwick - 回复
    ??? The T8 worked fine for me. Not sure what the difference would be.
    Fred Heineman - 回复
    Fare molta attenzione alla vite in fondo a destra, è facile (soprattutto se la punta del proprio cacciavite non è magnetizzata) che la vite si perda sotto alla Logic board. Se la punta del cacciavite non è magnetizzata consiglio o di utilizzare un magnete esterno o di utilizzare delle pinze mentre si svita la vite in modo da non incorrere in questo problema.
    Carlo Molta - 回复
  58. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 58 中的图像 1,1
    • Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
    • Depending on the age and model of your iMac, a T9 driver may work best.
    When reinstalling the logic board, install four screws loose. Insert thumb drives into the back in all slots to ensure alignment. Once aligned, then tighten screws.
    Gary Kelch - 回复
    On some models there is a tiny microphone cable connector, just above the lower left logic board screw. Remove by carefully pulling straight down. There is also a piece of insulating plastic w/adhesive on top of the screw which can be pulled off prior to removal. Save and reuse with the same screw on installation.
    Ed Beachwood - 回复
  59. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 59 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 59 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 59 中的图像 3,3
    • Tilt the top of the logic board away from the rear enclosure.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear case's screw posts.
    • The I/O boards at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
    When inserting the logic board back, pay attention of the position of the I/O connectors. When it is back in place, put a USB / Thunderbolt cable into the connectors to ensure the perfect alignment.
    Peter - 回复
    This is fantastic advice. I used a combination of USB and display port plugs to ensure proper alignment and help keep the logic board steady while i screwed it back in. Thank you!!
    kazoodac -
    Great technique. I plugged a cable into every port before tightening logic board screws.
    airshack - 回复
    ive gotten this far and i still have one question, i’m replacing my HDD With A SSD should i also remove the original Blade drive ? and run exclusively off the ssd, ? i wasn’t 100 on whether or not i was getting the fusion set up so i’m not in possession of a upgraded blade, so i though this was a good question id hadn’t seen asked.
    Eliasar - 回复
  60. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 60 中的图像 1,1
    • Remove the two 3.2 mm T5 screws securing the AirPort/Bluetooth card to the logic board.
  61. iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 61 中的图像 1,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 61 中的图像 2,3 iMac Intel 21.5" EMC 2544 AirPort/Bluetooth Card Replacement: 步骤 61 中的图像 3,3
    • Slightly lift the AirPort/Bluetooth card and pull it straight out its socket.
    • Do not use excessive force to pull the end of the AirPort/Bluetooth Card away from its socket on the logic board. Doing so may damage the socket.
    • When reinstalling the card, be sure it is properly seated before reinstalling the retaining screws.
    I addition to the two Torx5 screws, My Wi Fi bluetooth card was glued to the main board with a grey porous glue that was easy to peel off once I got the card loose.
    Runar Vaernes - 回复
结论
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
5等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,854 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
3条评论
I successfully upgraded the Wi-Fi Bluetooth card in my late 2012 iMac to 802.11ac following this guide! The new card is now the same as what´s in the new 2013 iMacs, I used the 2013 iMac teardown to find the right part:)
Runar Vaernes - 回复
Do I need to remove/clean the paste that locks the card before installing a new one? If I use a used one, what kind of paste do I have to use to replace the old one?
Pzucchi - 回复
I just bought a new BT card (a >2013 version!) and it works!!!! Just some advise before you start: follow the instructions above including step 28. At this point unscrew the big sized mainboard screws. This allows some movement so you can pull back the motherboard if needed and will avoid straining it to much. you can nog pull out the Bluetooth card without dismantling the whole computer! Putting the new card back also works fine this way. This Saves you massive time!
aarsentim - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 50
总计 8,904
