跳转到主内容
iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement
  1. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement, Power On Button: 步骤 1 中的图像 1,1
    • To get to the power button first remove the hard drive fan as seen in other guides.
  2. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 2 中的图像 1,1
    • This is a picture of the button in place with the connector to the logic board removed.
    • There are three plastic pins protruding up from the main back case that the button fits over. They appear to be slightly melted and mashed to hold it in place. I used a pocket knife to pry it up and off the posts.
  3. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 3 中的图像 1,2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 3 中的图像 2,2
    • Here it is with the back plate of the button pried off. This exposes a white plastic washer under it.
  4. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 4 中的图像 1,1
    • The center of the washer has a center locking pin to correctly place it on the back of the button. The washer is concave and the concave side faces the button, This gives the button a spring to it so that it will pop back out.
  5. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 5 中的图像 1,2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 5 中的图像 2,2
    • This is he back of the button that will now just push out. Picture #2 is with the button removed.
  6. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 步骤 6 中的图像 1,1
    • Test the button to see if it works.
    • After replacing the button, use something (like a low temperature soldering iron) that will melt the tops of the white plastic pegs to secure the button in place.
结论
4等其他人完成本指南。
mayer
于01/04/10注册
678,787 声望
创作了12篇指南
团队
MacHale Enterprises MacHale Enterprises 的会员
Business
1 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 38
总计 13,502
