跳转到主内容
加入维修社区 - 创建账户
iMac G5 17" Model A1058 Optical Drive Replacement
你所需要的
  1. iMac G5 17" Model A1058 Optical Drive Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
    添加评论
  2. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 2 中的图像 1,3 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 2 中的图像 2,3 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
    询问修复机器人
    添加评论
  3. iMac G5 17" Model A1058 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,1
    • Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
    询问修复机器人
    添加评论
  4. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 4 中的图像 1,3 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 4 中的图像 2,3 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Lift the optical drive near the connector to separate it from the logic board.
    • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
    • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
    • Lift the optical drive out of your iMac.
    • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
    询问修复机器人
    添加评论
  5. iMac G5 17" Model A1058 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,1
    • Remove the two 3.7 mm T6 Torx screws securing the optical drive connector board to the optical drive.
    询问修复机器人
    添加评论
  6. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Working from alternating sides of the board, use the flat end of a spudger to separate the optical drive connector board from the optical drive.
    • The socket in the optical drive is particularly deep, so don't pry the connector up too far from one side to avoid shearing the connector off the board.
    询问修复机器人
    添加评论
  7. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the optical drive connector board.
    询问修复机器人
    添加评论
  8. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 8 中的图像 1,2 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the two 4.5 mm shouldered T6 Torx screws from each side of the optical drive (four screws total).
    询问修复机器人
    添加评论
  9. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 9 中的图像 1,1
    • Insert a spudger into the gap between the optical drive and its cage near the optical drive connector.
    • Pry the optical drive away from the vibration isolating material along the inside of the cage.
    询问修复机器人
    添加评论
  10. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 10 中的图像 1,1
    • Pull the optical drive away from the cage by its open side.
    • It may be necessary to wiggle the optical drive as you pull it away from the cage to free it from the vibration isolating material.
    询问修复机器人
    添加评论
  11. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 11 中的图像 1,2 iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 11 中的图像 2,2
    • Use the tip of a spudger to push the two plastic bezel tabs away from their retaining slots on the top of the optical drive.
    询问修复机器人
    添加评论
  12. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 12 中的图像 1,1
    • Use the pointed end of a spudger to depress and release the bezel retaining tab on the side of the optical drive.
    询问修复机器人
    添加评论
  13. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 13 中的图像 1,1
    • If necessary, use the pointed tip of a spudger to release the two plastic bezel tabs from their slots on the bottom of the optical drive.
    询问修复机器人
    添加评论
  14. iMac G5 17" Model A1058 Optical Drive Replacement: 步骤 14 中的图像 1,1
    • Remove the plastic bezel from the optical drive.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 47
总计 15,970
