简介
If you are experience poor sound quality, or the sound is not properly dispensing, replacing the woofers can resolve these issues. This guide provides the step by step procedure to replacing this part.
你所需要的
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Pry off the mesh frame from the back side of the speaker with a plastic spudger until you hear a click noise when the clip is removed.
Remove the thirteen 11 mm Philips #1 screws from the perimeter of the plastic case.
Remove the screws from the center of the plastic case as well.
Lift the case up to expose the Woofer, Tweeter, and filter.
另外一个人完成了本指南。
