跳转到主内容
iHome iM71SC Base LED Replacement
你所需要的
  1. iHome iM71SC Base LED Replacement, iHome iM71SC Disassembly: 步骤 1 中的图像 1,1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Base LED Replacement: 步骤 2 中的图像 1,1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Base LED Replacement: 步骤 3 中的图像 1,1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Base LED Replacement: 步骤 4 中的图像 1,1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Base LED Replacement, Base LED: 步骤 5 中的图像 1,1
    • Locate the LED on the circuit board.
  6. iHome iM71SC Base LED Replacement: 步骤 6 中的图像 1,2 iHome iM71SC Base LED Replacement: 步骤 6 中的图像 2,2
    • Desolder the three connections to the old LED to remove it from the board.
    • Check out this awesome guide for soldering & desoldering instructions.
结论
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
于03/21/17注册
301 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 262
