跳转到主内容
iHome IH11 Speaker Replacement
你所需要的
  1. iHome IH11 Speaker Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Speaker Replacement: 步骤 2 中的图像 1,2 iHome IH11 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
  4. iHome IH11 Speaker Replacement: 步骤 4 中的图像 1,2 iHome IH11 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver.
    • Carefully lift speaker out of its casing.
  5. iHome IH11 Speaker Replacement: 步骤 5 中的图像 1,1
    • Unsolder the two wires that connect to the speaker.
结论
团队
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G9
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 351
