跳转到主内容
iHome IH11 Main Motherboard Replacement
你所需要的
  1. iHome IH11 Main Motherboard Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: 步骤 2 中的图像 1,2 iHome IH11 Main Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: 步骤 4 中的图像 1,2 iHome IH11 Main Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: 步骤 5 中的图像 1,1
    • Solder each wire to corresponding input on the motherboard.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G9
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 394
