跳转到主内容
iHome IH11 Dock Connector Replacement
你所需要的
  1. iHome IH11 Dock Connector Replacement, Dock Connector: 步骤 1 中的图像 1,1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: 步骤 2 中的图像 1,2 iHome IH11 Dock Connector Replacement: 步骤 2 中的图像 2,2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: 步骤 3 中的图像 1,1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
结论
3等其他人完成本指南。
Nick Knowles
于04/19/13注册
21 声望
创作了2篇指南
团队
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G9
5 名成员
创作了5篇指南
2条评论
Where can I buy a replacement dock connector?
A Ross - 回复
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,414
