跳转到主内容
iHome IH11 AC Power Adapter Replacement
你所需要的
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
  2. iHome IH11 AC Power Adapter Replacement: 步骤 2 中的图像 1,2 iHome IH11 AC Power Adapter Replacement: 步骤 2 中的图像 2,2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
  3. iHome IH11 AC Power Adapter Replacement: 步骤 3 中的图像 1,1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: 步骤 4 中的图像 1,2 iHome IH11 AC Power Adapter Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 AC Power Adapter Replacement: 步骤 5 中的图像 1,1
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
  6. iHome IH11 AC Power Adapter Replacement: 步骤 6 中的图像 1,2 iHome IH11 AC Power Adapter Replacement: 步骤 6 中的图像 2,2
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
结论
2等其他人完成本指南。
Nick Knowles
于04/19/13注册
21 声望
创作了2篇指南
团队
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G9
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 745
