跳转到主内容
iHip Fold-up Portable Speaker Replacement
你所需要的
  1. iHip Fold-up Portable Speaker Replacement, Removing the battery case cover: 步骤 1 中的图像 1,1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 步骤 2 中的图像 1,3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 步骤 2 中的图像 2,3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 步骤 2 中的图像 3,3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Replacement, Removing the screws: 步骤 3 中的图像 1,2 iHip Fold-up Portable Speaker Replacement, Removing the screws: 步骤 3 中的图像 2,2
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Replacement, Removing the back cover: 步骤 4 中的图像 1,2 iHip Fold-up Portable Speaker Replacement, Removing the back cover: 步骤 4 中的图像 2,2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker Replacement, Locating Speakers: 步骤 5 中的图像 1,1
    • Locate the two individual speakers on either side of the front cover.
  6. iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 步骤 6 中的图像 1,3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 步骤 6 中的图像 2,3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 步骤 6 中的图像 3,3
    • Use a plastic opening tool to scrape off the glue around the speakers.
    • Gently pull the speaker up to detach it from the front cover.
    • Desolder the black and red wires from the speaker unit.
    • Use a hot glue gun to secure the new speaker. Solder the black and red speaker wires back in place.
结论
Lisa
于10/13/14注册
207 声望
创作了2篇指南
团队
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G4
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 708
