跳转到主内容
加入维修社区 - 创建账户
iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement
你所需要的
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      询问修复机器人
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 2 中的图像 1,1
      • Lift the battery out of the computer.
      询问修复机器人
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again. The locking screw is in between the F5 and F6 keys and is a clear piece of plastic.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      询问修复机器人
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 4 中的图像 1,1
      • If the computer has an AirPort card installed, follow the next three steps to remove it.
      • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
      询问修复机器人
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 5 中的图像 1,1
      • Grasp the clear plastic tab on the AirPort card and pull toward the display.
      询问修复机器人
      添加评论
    4. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 6 中的图像 1,1
      • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
      询问修复机器人
      添加评论
    5. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 7 中的图像 1,1
      • Remove the four silver Phillips screws that secure the RAM shield.
      询问修复机器人
      添加评论
    6. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 8 中的图像 1,1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      询问修复机器人
      添加评论
    7. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 9 中的图像 1,1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
      询问修复机器人
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Lower Case: 步骤 10 中的图像 1,1
      • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 11 中的图像 1,1
      • Remove the three newly-revealed Phillips screws.
      询问修复机器人
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 12 中的图像 1,1
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
      询问修复机器人
      添加评论
    4. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 13 中的图像 1,1
      • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
      • The shorter screw is in the center of the computer.
      添加评论
    5. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 14 中的图像 1,1
      • Remove the two Phillips screws on either side of the battery contacts.
      询问修复机器人
      添加评论
    6. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 15 中的图像 1,1
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
      添加评论
    7. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 16 中的图像 1,1
      • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
      • Be careful not to break this clip!
      询问修复机器人
      添加评论
    8. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 17 中的图像 1,1
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
      询问修复机器人
      添加评论
    9. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 18 中的图像 1,1
      • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
      添加评论
    10. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 19 中的图像 1,1
      • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
      询问修复机器人
      添加评论
    11. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 20 中的图像 1,1
      • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
      添加评论
    12. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 21 中的图像 1,1
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
      询问修复机器人
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Bottom Shield: 步骤 22 中的图像 1,1
      • Remove the following 10 screws from the bottom shield:
      • Six 3 mm Phillips
      • Three 7.5 mm Phillips
      • One 14 mm Phillips
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 23 中的图像 1,1
      • Lift the bottom shield off.
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, DC-In Board: 步骤 24 中的图像 1,1
      • Remove the single Phillips screw securing the DC-In board.
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 25 中的图像 1,1
      • Disconnect the DC-In cable from the logic board.
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 26 中的图像 1,1
      • Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Upper Case: 步骤 27 中的图像 1,1
      • Remove the following 11 screws from the bottom of the computer:
      • Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
      • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
      • One 11 mm Phillips in the lower right corner. (if present)
      • Four 14.5 mm Phillips.
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 28 中的图像 1,1
      • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
      • Turn over the computer and open it.
      • Remove the 2 Phillips screws (3mm) from the edges of the keyboard area.
      • Remove the 4 mm Phillips screw from the lower left corner.
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 29 中的图像 1,1
      • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
      • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
      询问修复机器人
      添加评论
    4. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 30 中的图像 1,1
      • Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
      询问修复机器人
      添加评论
    5. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 31 中的图像 1,1
      • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
      • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
      添加评论
    6. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 32 中的图像 1,1
      • Carefully disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Top Shield: 步骤 33 中的图像 1,1
      • The screw circled in orange may not be present in some models.
      • Remove the following 16 screws:
      • Thirteen 3 mm Phillips.
      • One 3 mm Phillips. (actual screw not present in image)
      • Two 4 mm Phillips.
      • Be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
      • Missing in this photo is the Bluetooth antenna present in some iBooks. It is located at the upper right corner of the battery compartment, just above the 4mm screw. You can see the bracket for the antenna in the photo. It is the two I-shaped holes just above the 4mm screw that must be removed in this step. To remove the antenna, slide it toward the LCD, and tilt it vertically back towards yourself.
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 34 中的图像 1,1
      • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
      • If your iBook has Bluetooth, as discussed in the previous step, you will need to slide the antenna through the lower I-shaped hole in the shield before completely removing the shield.
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Hard Drive: 步骤 35 中的图像 1,1
      • Turn the computer over and disconnect the orange hard drive cable, removing tape as necessary.
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 36 中的图像 1,1
      • Remove the four Phillips screws securing the hard drive to the metal framework.
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 37 中的图像 1,1
      • Lift the hard drive up, carefully guiding the cable through the slot in the lower case.
      询问修复机器人
      添加评论
    1. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement, Hard Drive: 步骤 38 中的图像 1,1
      • Remove the hard drive brackets from the left and right sides of the hard drive.
      询问修复机器人
      添加评论
    2. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 39 中的图像 1,1
      • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
      询问修复机器人
      添加评论
    3. iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement: 步骤 40 中的图像 1,1
      • Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
      • This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      添加评论
结论
取消:我没有完成这个指南。
158等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了635篇指南
17指南评论
isit really possible change 320gb hard drive to ibook g4 1.33 14". i heard motherboard doesnt support bigger than 128Gb?
chacal - 回复 分享
I put one in and now the machine doesn't recognize the drive.
I'm gonna just pull it out and use it as an external until I can figure it out.
olefaithfull - 回复 分享
来自 chacal 的话:
I just went through the whole process and it worked fine. Used super duper to copy the original drive then restored using target disk mode and my MBP
sapugh - 回复 分享
Make sure that you print out the screw sheet (PDF), and lay out all the screws on the 3 sheets of paper. It makes it easy to keep track of all the screws, and you won't make a mistake when putting every thing back. Also, go slow and take your time. You don't want to rush on the HD replacement. It took me about 2 hours. The hardest part was take the case apart. You may want to look at a youtube video called "iBook G4 Hard Drive Swap", by smalldog.com. The video shows how the case comes apart, and puts your mind at ease when you hear the cracking sounds as the tabs are released. The instructions on the ifixit.com web site were awesome.
ticzon - 回复 分享
来自 sapugh 的话:
I too installed a 320 gb WD Hard Drive in a iBook G4. No problems. However, I did test the drive with one of my hard drives utilities to make the sure there were no write errors before installing the drive.
ticzon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 114
总计 155,347
