跳转到主内容
加入维修社区 - 创建账户
eMac RAM Replacement
你所需要的
  1. eMac RAM Replacement, RAM: 步骤 1 中的图像 1,3 eMac RAM Replacement, RAM: 步骤 1 中的图像 2,3 eMac RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • The 700MHz thru the second 1 GHz models use PC 133 sticks. The maximum RAM is 1 GB. The second two 1 GHz models and higher machines use PC 2700 memory sticks and have a maximum RAM of 2GB.
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
    询问修复机器人
    添加评论
  2. eMac RAM Replacement: 步骤 2 中的图像 1,2 eMac RAM Replacement: 步骤 2 中的图像 2,2
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
    询问修复机器人
    添加评论
  3. eMac RAM Replacement: 步骤 3 中的图像 1,2 eMac RAM Replacement: 步骤 3 中的图像 2,2
    • There are two RAM slots. Release the RAM by pushing the white outer tabs. Then pull the RAM straight out.
    • Place new RAM in slots and press with both thumbs on each end till you feel them seat.
    • Replace the access panel. Turn it over and plug it in. Boot the machine up and click the Apple logo in the menu bar and then go to "about this Mac", to check to see that the RAM is being recognised properly.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
29等其他人完成本指南。
mayer
于01/04/10注册
690,423 声望
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 78
总计 22,215
