当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Remove the six 2 mm PH0 screws on the bottom of the device.
Four of those screws are located under the foot pads.
Gently remove the bottom of the device.
Remove the four 1.8 mm J1 screws.
Remove the two 2mm PH0 screws.
Gently pick up the mother board
Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Desolder the two points following the instructions included in your soldering kit as you remove the light.
FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
You can follow iFixit's guide to soldering here.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于03/11/15注册
757 声望
创作了6篇指南
徽章: 16
+ 13更多徽章
UCCS-PANKO-S15S4G4
3 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 11
总计 173
