当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
You can follow iFixit's guide to soldering here.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
