跳转到主内容
dreamGEAR Quad Dock Pro Electrical Port Replacement
你所需要的
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: 步骤 1 中的图像 1,2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: 步骤 1 中的图像 2,2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 2 中的图像 1,2 dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 2 中的图像 2,2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 3 中的图像 1,1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: 步骤 4 中的图像 1,2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: 步骤 4 中的图像 2,2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 5 中的图像 1,1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 6 中的图像 1,2 dreamGEAR Quad Dock Pro Electrical Port Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 步骤 7 中的图像 1,3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 步骤 7 中的图像 2,3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
结论
另外一个人完成了本指南。
Jacob
于03/11/15注册
757 声望
创作了6篇指南
团队
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 330
