跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Microsoft Zune 80,应参考我们的维修指南
  1. Zune 80 GB Teardown, Zune 80 GB Teardown: 步骤 1 中的图像 1,1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap located on top of the device.
  2. Zune 80 GB Teardown: 步骤 2 中的图像 1,1
    • There are two T4 screws under the cap. Remove both screws with a T4 screwdriver.
    • WARNING: Be careful when removing the screws since they can strip very easily.
  3. Zune 80 GB Teardown: 步骤 3 中的图像 1,2 Zune 80 GB Teardown: 步骤 3 中的图像 2,2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are five clips on each side and two on the bottom.
    • WARNING: Be careful not to press the tools in too far because there are exposed cables right inside the edge of the device.
  4. Zune 80 GB Teardown: 步骤 4 中的图像 1,2 Zune 80 GB Teardown: 步骤 4 中的图像 2,2
    • Remove the silver tape from the bottom center and the top right of the device. This allows access to the hard drive and the battery.
  5. Zune 80 GB Teardown: 步骤 5 中的图像 1,3 Zune 80 GB Teardown: 步骤 5 中的图像 2,3 Zune 80 GB Teardown: 步骤 5 中的图像 3,3
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive.
    • Gently push towards the bottom of the device on the black bar until you hear a click sound. It is now disengaged from the hard drive.
    • If the cable does not come off easily, the black bar has not been un-clicked.
    • Now, gently pull the orange hard drive cable to remove it from the hard drive cable.
    • Lift the hard drive out of the device.
  6. Zune 80 GB Teardown: 步骤 6 中的图像 1,2 Zune 80 GB Teardown: 步骤 6 中的图像 2,2
    • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  7. Zune 80 GB Teardown: 步骤 7 中的图像 1,1
    • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  8. Zune 80 GB Teardown: 步骤 8 中的图像 1,3 Zune 80 GB Teardown: 步骤 8 中的图像 2,3 Zune 80 GB Teardown: 步骤 8 中的图像 3,3
    • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
    • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  9. Zune 80 GB Teardown: 步骤 9 中的图像 1,1
    • The orange audio board cable is clipped in with a small black bar, like the hard drive cable.
    • Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when it disengages.
    • If the cable does not come off easily, the black bar has not been unclicked.
  10. Zune 80 GB Teardown: 步骤 10 中的图像 1,1
    • Flip the black bar to unclip the left side of the hard drive cable. You may now remove the hard drive cable.
  11. Zune 80 GB Teardown: 步骤 11 中的图像 1,2 Zune 80 GB Teardown: 步骤 11 中的图像 2,2
    • Remove the two T4 screws that hold the charging port on the bottom of the device.
    • Remove the charging port.
  12. Zune 80 GB Teardown: 步骤 12 中的图像 1,3 Zune 80 GB Teardown: 步骤 12 中的图像 2,3 Zune 80 GB Teardown: 步骤 12 中的图像 3,3
    • Remove the battery from the device with the cables still connected.
    • Carefully lift up the logic board located at the base of the Zune.
    • Unclip the orange ribbon cable in the same manner as in the previous steps.
    • Remove the logic board from the Zune, leaving the black wire connected.
  13. Zune 80 GB Teardown: 步骤 13 中的图像 1,2 Zune 80 GB Teardown: 步骤 13 中的图像 2,2
    • Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
    • The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
    • Remove the assembly and the battery together as one unit.
  14. Zune 80 GB Teardown: 步骤 14 中的图像 1,2 Zune 80 GB Teardown: 步骤 14 中的图像 2,2
    • Gently pry the screen unit from the black, plastic front frame.
koolkid
于10/28/09注册
518 声望
创作了2篇指南
团队
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G5
5 名成员
创作了5篇指南
一条评论
you can do the same with Zune 120, 4, 8 and 16
PROHIBIDO EL PASO - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 53
总计 16,526
