跳转到主内容
Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
你所需要的
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: 步骤 1 中的图像 1,2 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: 步骤 1 中的图像 2,2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 2 中的图像 1,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 2 中的图像 2,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 2 中的图像 3,3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 步骤 3 中的图像 1,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 步骤 3 中的图像 2,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 步骤 3 中的图像 3,3
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 4 中的图像 1,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 4 中的图像 2,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 5 中的图像 1,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 5 中的图像 2,3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 5 中的图像 3,3
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 步骤 6 中的图像 1,1
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
结论
Luke Selby
于01/20/16注册
636 声望
创作了4篇指南
团队
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 729
