跳转到主内容
Zoomer Jurassic World Indominus Rex Motherboard Replacement
你所需要的
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 2 中的图像 1,2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 3 中的图像 1,2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 3 中的图像 2,2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 5 中的图像 1,2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Use caution while soldering to avoid being burned.
结论
Anh Le
于01/20/16注册
504 声望
创作了3篇指南
团队
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 858
