跳转到主内容
Zoomer Dino Boomer Nose Sensor Replacement
你所需要的
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: 步骤 1 中的图像 1,2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: 步骤 1 中的图像 2,2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: 步骤 2 中的图像 1,2 Zoomer Dino Boomer Nose Sensor Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: 步骤 3 中的图像 1,2 Zoomer Dino Boomer Nose Sensor Replacement: 步骤 3 中的图像 2,2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: 步骤 4 中的图像 1,2 Zoomer Dino Boomer Nose Sensor Replacement: 步骤 4 中的图像 2,2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: 步骤 5 中的图像 1,3 Zoomer Dino Boomer Nose Sensor Replacement: 步骤 5 中的图像 2,3 Zoomer Dino Boomer Nose Sensor Replacement: 步骤 5 中的图像 3,3
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: 步骤 6 中的图像 1,1
    • Remove and replace the nose sensor.
结论
Lauren Mannix
于08/29/15注册
398 声望
创作了3篇指南
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,327
