简介
If the charger for your T26 Zerodate mouse has not been working due to a damaged USB-C charging port, this guide can be used to help remove and replace the charging port so you can use your mouse to its full potential again. Follow this step-by-step guide with a plastic opening tool to pry the mouse open, a Phillips screwdriver to remove the plates, and a soldering iron to begin replacing the port. New USB-C ports can be ordered online.
你所需要的
Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
