跳转到主内容
Zerodate T26 Scroll Wheel CMOS Sensor Replacement
你所需要的
  1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel: 步骤 1 中的图像 1,2 Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel: 步骤 1 中的图像 2,2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 2 中的图像 1,2 Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 3 中的图像 1,2 Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 4 中的图像 1,2 Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 5 中的图像 1,2 Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 5 中的图像 2,2
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: 步骤 6 中的图像 1,3 Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: 步骤 6 中的图像 2,3 Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: 步骤 6 中的图像 3,3
    • Remove the battery from the mouse as shown, and set it to the side for later.
    • This should now allow you to gently pull the circuit board up from the bottom of the mouse.
    • Please be very careful when pulling up the circuit board. Yanking it out could result in further damage to the mouse. Make sure you go slow and steady.
  7. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: 步骤 7 中的图像 1,1
    • To replace the CMOS sensor attached to the circuit board, carefully de-solder it from the board, found here.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
结论
Janice Rullan
于03/13/23注册
662 声望
创作了6篇指南
团队
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 113
