跳转到主内容
Zerodate T26 Main Clicker Replacement
你所需要的
  1. Zerodate T26 Main Clicker Replacement, Scroll Wheel: 步骤 1 中的图像 1,2 Zerodate T26 Main Clicker Replacement, Scroll Wheel: 步骤 1 中的图像 2,2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Main Clicker Replacement: 步骤 2 中的图像 1,2 Zerodate T26 Main Clicker Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Main Clicker Replacement: 步骤 3 中的图像 1,2 Zerodate T26 Main Clicker Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Main Clicker Replacement: 步骤 4 中的图像 1,2 Zerodate T26 Main Clicker Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Main Clicker Replacement: 步骤 5 中的图像 1,2 Zerodate T26 Main Clicker Replacement: 步骤 5 中的图像 2,2
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Main Clicker Replacement, Main Clicker: 步骤 6 中的图像 1,1
    • If the switches themselves are the issue, first dip a Q-tip into some isopropyl alcohol and rub it into and around the white switches. This should remove any dirt or debris that is impeding the operation of the switch.
    • The red switch seen in this image would otherwise be covered by the scroll wheel.
  7. Zerodate T26 Main Clicker Replacement: 步骤 7 中的图像 1,1
    • If the switches still do not work, then they need to be replaced. Mouse clicker switches can be purchased online, please refer to this soldering guide for the steps needed to remove and replace these switches.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove clicker switches.
结论
Janice Rullan
于03/13/23注册
662 声望
创作了6篇指南
团队
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 129
