跳转到主内容
Zeki TBQG884B LCD Screen Replacement
你所需要的
  1. Zeki TBQG884B LCD Screen Replacement, Rear Case: 步骤 1 中的图像 1,2 Zeki TBQG884B LCD Screen Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B LCD Screen Replacement: 步骤 3 中的图像 1,2 Zeki TBQG884B LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B LCD Screen Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
  9. Zeki TBQG884B LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,1
    • Use an opening tool to detach the clip between the front frame, and the metal loader.
    • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
  10. Zeki TBQG884B LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Lift the metal loader up and separate it from the LCD screen.
    • Detach each piece slowly to avoid damaging or dropping any fragile parts.
结论
2等其他人完成本指南。
David Wyman
于09/16/15注册
346 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G3
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,393
