简介
This guide will help you to disassemble your tablet and replace your battery. This procedure should take no more then forty minutes to complete. The process will include using a soldering tool and sharp objects.
你所需要的
Remove the back casing by slowly popping each tab out with a plastic opening tool.
To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
另外一个人完成了本指南。
3指南评论
will this be the same for a tbqc 1065b?
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
