跳转到主内容
加入维修社区 - 创建账户
Zeepad 7.0 Screen Replacement
你所需要的
  1. Zeepad 7.0 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Zeepad 7.0 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: 步骤 3 中的图像 1,2 Zeepad 7.0 Screen Replacement: 步骤 3 中的图像 2,2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: 步骤 4 中的图像 1,1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: 步骤 5 中的图像 1,2 Zeepad 7.0 Screen Replacement: 步骤 5 中的图像 2,2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: 步骤 6 中的图像 1,3 Zeepad 7.0 Screen Replacement: 步骤 6 中的图像 2,3 Zeepad 7.0 Screen Replacement: 步骤 6 中的图像 3,3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: 步骤 7 中的图像 1,3 Zeepad 7.0 Screen Replacement: 步骤 7 中的图像 2,3 Zeepad 7.0 Screen Replacement: 步骤 7 中的图像 3,3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • 如何焊接和拆焊
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
结论
To reassemble your device, follow these instructions in order.
另外一个人完成了本指南。
Harry Winter
于03/26/18注册
157 声望
撰写一个指南
团队
IUPUI, Team S2-G1, Harley Spring 2018 IUPUI, Team S2-G1, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S2G1
3 名成员
创作了4篇指南
2指南评论
where do you buy the screen?
Zuzzi Z Amend - 回复
i need a battery an a screen? is their a place on this page where to get them?
Zuzzi Z Amend - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 620
