跳转到主内容
Zebra ZP 450 Power Switch Replacement
你所需要的
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: 步骤 4 中的图像 1,3 Zebra ZP 450 Power Switch Replacement: 步骤 4 中的图像 2,3 Zebra ZP 450 Power Switch Replacement: 步骤 4 中的图像 3,3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: 步骤 5 中的图像 1,1
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 161
