跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Zanco Tiny T1,请使用我们的维修手册
  1. Zanco Tiny T1 Teardown, Zanco Tiny T1 Teardown: 步骤 1 中的图像 1,2 Zanco Tiny T1 Teardown, Zanco Tiny T1 Teardown: 步骤 1 中的图像 2,2
    • The Tiny T1 may be small—but is it mighty? We'll let its specs do the talking:
    • Mediatek MTK6261D SoC
    • 0.49" OLED display with 64 x 32 pixel resolution (146 ppi)
    • Built-in voice changer
    • 32 MB RAM and 32 MB ROM
    • Backlit keyboard
    • 2G network connectivity
    • MicroUSB port
  2. Zanco Tiny T1 Teardown: 步骤 2 中的图像 1,3 Zanco Tiny T1 Teardown: 步骤 2 中的图像 2,3 Zanco Tiny T1 Teardown: 步骤 2 中的图像 3,3
    • For size reference, we've enlisted the help of a certain furry rebel. Don't worry—we'll transport him back to the Rebellion when we're done with him.
    • While it's not the most popular tiny phone form factor, the T1's chocolate bar layout makes dialing and texting with human-sized fingers a breeze.
    • The metal back case is smooth except for a regulatory sticker and speaker grille. No fragile glass panel to shatter. No unsightly rear camera bump.
  3. Zanco Tiny T1 Teardown: 步骤 3 中的图像 1,3 Zanco Tiny T1 Teardown: 步骤 3 中的图像 2,3 Zanco Tiny T1 Teardown: 步骤 3 中的图像 3,3
    • A "micro"-USB port occupies the bottom of the phone—and Zanco has managed to squeeze in a pinhole microphone alongside it.
    • Nano is such a relative word, as the "nano" SIM slot dominates the right edge of the phone.
    • If you're prone to butt-dialing people, the Tiny T1 is not for you.
    • Does size matter? We compare the Tiny T1 to its modern compatriots: a tech writer's LG ENV3 and a Samsung Galaxy S9+.
  4. Zanco Tiny T1 Teardown: 步骤 4 中的图像 1,3 Zanco Tiny T1 Teardown: 步骤 4 中的图像 2,3 Zanco Tiny T1 Teardown: 步骤 4 中的图像 3,3
    • Opening a phone of this scale requires specialty tools. Fortunately, iFixit has got it covered.
    • Despite its retro aesthetic, this opening procedure is far from obsolete. Some micro spudger action frees up the front clips, and the top plastic plate is free!
    • Unlike with some phones, we encounter no proprietary screws here.
    • We move the keypad aside and find the button pad soldered to the board beneath.
    • To supply backlight to the keypad, two white adhesive pads diffuse light from four surface-mounted LEDs underneath.
  5. Zanco Tiny T1 Teardown: 步骤 5 中的图像 1,3 Zanco Tiny T1 Teardown: 步骤 5 中的图像 2,3 Zanco Tiny T1 Teardown: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • While most modern phones are held together by an army of screws and nasty adhesives, the Tiny T1 has none of that. Zero screws! Zero adhesives!
    • The entire innards pop out with a single pry with a (normal) sized spudger.
    • The likely lesson here: to easily open normal-sized phones, we need a giant spudger.
    • Who says small can't be repairable? (Looking at you, AirPods.)
  6. Zanco Tiny T1 Teardown: 步骤 6 中的图像 1,2 Zanco Tiny T1 Teardown: 步骤 6 中的图像 2,2
    • Here we have the inner workings of the Tiny T1—all of them. It's just one board, with (nearly) everything soldered to it:
    • Speaker
    • Microphone capsule
    • High tech Bluetooth antenna (it's a wire)
    • "Nano" SIM slot, ironically hogging nearly half the board
    • Two mysterious pogo pins, which are accessible from outside—possibly for charging? Accessory port? A tiny taser?
    • 200 mAh 0.74 Wh battery (for comparison, the ENV3 has 3.5 Wh, while the Galaxy S9+ weighs in at 13.48 Wh)
    • While the S9+ battery packs over eighteen times the capacity, we doubt that its standby scales linearly to the Tiny T1's three-day rating.
  7. Zanco Tiny T1 Teardown: 步骤 7 中的图像 1,1
    • What's the bare minimum amount of silicon needed for a functioning mobile phone? We're not sure, but this can't be far off:
    • Mediatek MT6261DA SoC
    • RDA Microelectronics RDA6625 Front-end module
    • Likely li-ion battery charger ic
    • 26 MHz oscillator
  8. Zanco Tiny T1 Teardown: 步骤 8 中的图像 1,1
    • That's a wrap to this Tiny Teardown!
    • The T1 shows you can make a working phone with just a little hardware—and with technological advancements, you can make it that much little-er.
    • We've come a long way from the first mobile phones of over forty years ago, even surpassing the wildest concepts from spy films and science fiction.
    • ... Which just means that modern designers of fictional gadgets have to keep upping their game.
  9. 最后的想法
    • The phone is held together by clips alone, making the opening procedure easy and painless.
    • The front plastic plate, which is prone to cracking, is easily replaceable.
    • Most components, including the battery, are soldered to the motherboard, making repairs difficult.
    可修复性评分
    5
    可修复性10分中得5分
    (10是最容易修复)
13条评论
Nice tear down. I did notice the tiny pliers with blue handles. I believe that is from one of the Pocher 1/8 scale car kits, possibly from the Ferrari Testarossa tool kits. Obviously it is just for decoration!
rayramirez - 回复
Oh no, this phone has a definite purpose. Although chances are if you don’t know what that purpose is, you probably don’t need one 😂
Mike Hayes -
IDK if I edited it correctly, but I tried to get the “Y” in “N.I.F.T.Y!” at the top to link to the ifixit YouTube channel.
Tommy Gurreri - 回复
Tommy, that’s a genius idea! It didn’t turn out properly but I got it worked out.
Arthur Shi -
So this is a real phone!?
kc8wzm - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 60
总计 8,933
