跳转到主内容
ZTE Prestige 2 Power and Volume Buttons Replacement
你所需要的
  1. ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 步骤 1 中的图像 3,3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Power and Volume Buttons Replacement: 步骤 2 中的图像 1,2 ZTE Prestige 2 Power and Volume Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 步骤 3 中的图像 1,3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 步骤 3 中的图像 2,3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Power and Volume Buttons Replacement: 步骤 4 中的图像 1,3 ZTE Prestige 2 Power and Volume Buttons Replacement: 步骤 4 中的图像 2,3 ZTE Prestige 2 Power and Volume Buttons Replacement: 步骤 4 中的图像 3,3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: 步骤 5 中的图像 1,2 ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: 步骤 5 中的图像 2,2
    • Use the curved tweezers to pull upwards and out on the the thin plastic attached on both sides of the power button and volume buttons. This process should allow the buttons to pop right out.
结论
Mackenzie Peterson
于02/04/20注册
169 声望
创作了2篇指南
团队
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 92
