跳转到主内容
ZTE Prestige 2 Motherboard Replacement
你所需要的
  1. ZTE Prestige 2 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Prestige 2 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Prestige 2 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Motherboard Replacement: 步骤 2 中的图像 1,2 ZTE Prestige 2 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. ZTE Prestige 2 Motherboard Replacement, Back Panel: 步骤 3 中的图像 1,3 ZTE Prestige 2 Motherboard Replacement, Back Panel: 步骤 3 中的图像 2,3 ZTE Prestige 2 Motherboard Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Motherboard Replacement: 步骤 4 中的图像 1,3 ZTE Prestige 2 Motherboard Replacement: 步骤 4 中的图像 2,3 ZTE Prestige 2 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the three 3 mm Phillips #00 screws on the edges of the motherboard.
  6. ZTE Prestige 2 Motherboard Replacement: 步骤 6 中的图像 1,3 ZTE Prestige 2 Motherboard Replacement: 步骤 6 中的图像 2,3 ZTE Prestige 2 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use the iFixit opening tool to dig under the sticker where the volume and the power buttons are located on both sides.
  7. ZTE Prestige 2 Motherboard Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the curved tweezers to gently remove the black cable running down the left side of the device and disconnect it from its socket.
  8. ZTE Prestige 2 Motherboard Replacement: 步骤 8 中的图像 1,3 ZTE Prestige 2 Motherboard Replacement: 步骤 8 中的图像 2,3 ZTE Prestige 2 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Use the curved tweezers to then unlock each of the ZIF connectors and pull the cables out.
    • The motherboard should now be able to fully disconnect from the rest of the device.
结论
另外一个人完成了本指南。
Maria Stock
于01/31/20注册
524 声望
创作了5篇指南
团队
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 214
