跳转到主内容
ZTE Prestige 2 Front-Facing Camera Replacement
你所需要的
  1. ZTE Prestige 2 Front-Facing Camera Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Prestige 2 Front-Facing Camera Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Prestige 2 Front-Facing Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 ZTE Prestige 2 Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: 步骤 3 中的图像 1,3 ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: 步骤 3 中的图像 2,3 ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Front-Facing Camera Replacement: 步骤 4 中的图像 1,3 ZTE Prestige 2 Front-Facing Camera Replacement: 步骤 4 中的图像 2,3 ZTE Prestige 2 Front-Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 5 中的图像 1,2 ZTE Prestige 2 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 5 中的图像 2,2
    • Use the curved tweezers to lift up the press fit camera connector.
    • The front facing camera is located directly to the left of the rear facing camera.
    • Lift out the front facing camera.
结论
Maria Stock
于01/31/20注册
524 声望
创作了5篇指南
团队
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 83
