跳转到主内容
ZTE Max XL Display Replacement
你所需要的
  1. ZTE Max XL Display Replacement, Display: 步骤 1 中的图像 1,2 ZTE Max XL Display Replacement, Display: 步骤 1 中的图像 2,2
    • Before disassembly, assure the phone is powered off.
    • Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
  2. ZTE Max XL Display Replacement: 步骤 2 中的图像 1,1
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide
    • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Display Replacement: 步骤 3 中的图像 1,3 ZTE Max XL Display Replacement: 步骤 3 中的图像 2,3 ZTE Max XL Display Replacement: 步骤 3 中的图像 3,3
    • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
    • There are 3 tabs on top and bottom and 6 on each side.
  4. ZTE Max XL Display Replacement: 步骤 4 中的图像 1,2 ZTE Max XL Display Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
  5. ZTE Max XL Display Replacement: 步骤 5 中的图像 1,1
    • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
  6. ZTE Max XL Display Replacement: 步骤 6 中的图像 1,1
    • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
  7. ZTE Max XL Display Replacement: 步骤 7 中的图像 1,1
    • Use an opening tool between the screen and side trim battery cover to remove the screen.
  8. ZTE Max XL Display Replacement: 步骤 8 中的图像 1,2 ZTE Max XL Display Replacement: 步骤 8 中的图像 2,2
    • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
  9. ZTE Max XL Display Replacement: 步骤 9 中的图像 1,2 ZTE Max XL Display Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Using the iFixit opening tools carefully pry the edge of the battery away from the casing.
    • Do not bend or puncture the battery during this process.
    • If the battery does not lift away freely, use careful amounts of isopropyl alcohol to help soften the adhesive. Gently work a thin opening pick or plastic card along the underside of the battery, pushing the card through the adhesive while lifting the battery free.
  10. ZTE Max XL Display Replacement: 步骤 10 中的图像 1,1
    • After taking off the battery and disconnecting all the metal tabs underneath, using the iOPener to break the adhesive between the display and the circuit.
  11. ZTE Max XL Display Replacement: 步骤 11 中的图像 1,2 ZTE Max XL Display Replacement: 步骤 11 中的图像 2,2
    • Use the plastic opening pick in the iFixit kit to wedge between the display and circuit.
    • Be sure not to damage the wire connecting the display to the circuit.
    • Replace the display and resemble the device following the reverse order
结论
4等其他人完成本指南。
Isaac Ssaku
于04/11/22注册
293 声望
撰写一个指南
团队
IUPUI, Team 1-2, Harley Spring 2022 IUPUI, Team 1-2, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 144
