跳转到主内容
加入维修社区 - 创建账户
ZTE Maven 2 Screen Replacement
你所需要的
  1. ZTE Maven 2 Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 ZTE Maven 2 Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 ZTE Maven 2 Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Screen Replacement, Battery: 步骤 2 中的图像 1,1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Screen Replacement, MicroSD Card: 步骤 3 中的图像 1,2 ZTE Maven 2 Screen Replacement, MicroSD Card: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Screen Replacement, Midframe: 步骤 4 中的图像 1,1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Screen Replacement: 步骤 5 中的图像 1,3 ZTE Maven 2 Screen Replacement: 步骤 5 中的图像 2,3 ZTE Maven 2 Screen Replacement: 步骤 5 中的图像 3,3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Screen Replacement, Motherboard: 步骤 6 中的图像 1,3 ZTE Maven 2 Screen Replacement, Motherboard: 步骤 6 中的图像 2,3 ZTE Maven 2 Screen Replacement, Motherboard: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Screen Replacement: 步骤 7 中的图像 1,2 ZTE Maven 2 Screen Replacement: 步骤 7 中的图像 2,2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Screen Replacement: 步骤 8 中的图像 1,2 ZTE Maven 2 Screen Replacement: 步骤 8 中的图像 2,2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Screen Replacement, Daughterboard: 步骤 9 中的图像 1,1
    • Remove the daughterboard containing the charging port.
  10. ZTE Maven 2 Screen Replacement, Screen: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Detach the ribbon cable connecting the camera to the device.
    • Use blunt tweezers to pull the camera off.
    • What's left in your hands after removing the camera is the screen component. This is what gets replaced.
    • The screw holes for the midframe and motherboard overlap. Plan out which screws will go where.
结论
Hewot Takele
于09/06/22注册
73 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 331
