跳转到主内容
ZTE Lever Power Button Replacement
你所需要的
  1. ZTE Lever Power Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Power Button Replacement: 步骤 2 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Power Button Replacement: 步骤 3 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 3 中的图像 2,2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Power Button Replacement: 步骤 4 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Power Button Replacement: 步骤 5 中的图像 1,1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Power Button Replacement, Volume Buttons: 步骤 6 中的图像 1,1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Power Button Replacement: 步骤 7 中的图像 1,3 ZTE Lever Power Button Replacement: 步骤 7 中的图像 2,3 ZTE Lever Power Button Replacement: 步骤 7 中的图像 3,3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Power Button Replacement: 步骤 8 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Power Button Replacement: 步骤 9 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 9 中的图像 2,2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Power Button Replacement, Power Button: 步骤 10 中的图像 1,1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Power Button Replacement: 步骤 11 中的图像 1,2 ZTE Lever Power Button Replacement: 步骤 11 中的图像 2,2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
结论
Michael Gonzalez
于01/29/18注册
501 声望
创作了4篇指南
团队
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 230
