跳转到主内容
Yamaha YPG-225 Keys Replacement
你所需要的
  1. Yamaha YPG-225 Keys Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: 步骤 2 中的图像 1,1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: 步骤 3 中的图像 1,1
    • Locate the six batteries and remove them from the battery cavity.
    what type of batteries? and how much ?
    thanks godbless
    colladonelson - 回复
  4. Yamaha YPG-225 Keys Replacement, Faceplate: 步骤 4 中的图像 1,1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: 步骤 5 中的图像 1,1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: 步骤 6 中的图像 1,1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: 步骤 7 中的图像 1,1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: 步骤 8 中的图像 1,2 Yamaha YPG-225 Keys Replacement: 步骤 8 中的图像 2,2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: 步骤 9 中的图像 1,1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: 步骤 10 中的图像 1,1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: 步骤 11 中的图像 1,2 Yamaha YPG-225 Keys Replacement: 步骤 11 中的图像 2,2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: 步骤 12 中的图像 1,1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
结论
7等其他人完成本指南。
Kevin Green
于09/18/12注册
308 声望
创作了2篇指南
团队
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G62
2 名成员
创作了6篇指南
3指南评论
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - 回复
Great article. Thank you so much.
Andreas Devig - 回复
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 21,328
