跳转到主内容
Xtreme Gaming XG-700 Internal Switch Replacement
你所需要的
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: 步骤 1 中的图像 1,1
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 3 中的图像 1,3 Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 3 中的图像 2,3 Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 3 中的图像 3,3
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 4 中的图像 1,2 Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 4 中的图像 2,2
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 6 中的图像 1,2 Xtreme Gaming XG-700 Internal Switch Replacement: 步骤 6 中的图像 2,2
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
结论
另外一个人完成了本指南。
Nam Nguyen
于06/30/22注册
154 声望
撰写一个指南
团队
York University, Team M-18, Allen Summer 2022 York University, Team M-18, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG18
1 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 41
总计 924
