跳转到主内容
Xiaomi Redmi Note Headphone Jack Replacement
你所需要的
  1. Xiaomi Redmi Note Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 2 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 3 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Headphone Jack Replacement, Midframe: 步骤 4 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement, Midframe: 步骤 4 中的图像 2,2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 5 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: 步骤 6 中的图像 1,3 Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: 步骤 6 中的图像 2,3 Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: 步骤 7 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: 步骤 7 中的图像 2,2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Xiaomi Redmi Note Headphone Jack Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Locate the three ZIF connectors on the motherboard.
  9. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 9 中的图像 1,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 9 中的图像 2,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 10 中的图像 1,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 10 中的图像 2,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 10 中的图像 3,3
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 11 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 11 中的图像 2,2
    • Remove the two 2.9mm Philips #00 screws.
  12. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 12 中的图像 1,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 12 中的图像 2,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 12 中的图像 3,3
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 13 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 13 中的图像 2,2
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 14 中的图像 1,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 14 中的图像 2,3 Xiaomi Redmi Note Headphone Jack Replacement: 步骤 14 中的图像 3,3
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
  15. Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: 步骤 15 中的图像 1,2 Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: 步骤 15 中的图像 2,2
    • Flip over the motherboard and locate the headphone jack at the top left corner.
    • Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
    • Learn how to solder and desolder here.
  16. Xiaomi Redmi Note Headphone Jack Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to pull off the headphone jack from the motherboard.
结论
7等其他人完成本指南。
Zongyi Li
于04/26/17注册
1,623 声望
创作了3篇指南
团队
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G4
4 名成员
创作了16篇指南
6指南评论
You have mentioned it in detailed, but can you mentioned the actual way or sequence of soldering six legs of the jack?
Can you mention the part number of redmi note headphone jack?
link where the jack will be available.
Hemant Kshirsagar - 回复
I want to buy head phone jack, where the jack will
manu tm manu - 回复
You can visit iSparehub.com
iSparehub. Com -
Hey, hast du eine Ahnung, wo man eine Kopfhörerbuchse als Ersatzteil für ein Xiaomi Redmi Note 5 Global herbekommt? Das wäre klasse.
Mathias Bork - 回复
Redmi note 4 earphone jack replacement Ka price Kya hai
Rinku Poonia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 57
总计 40,635
