简介
This guide demonstrates how to replace the laser distance sensor on your Roborock S5 robotic vacuum cleaner. The laser distance sensor is the periscopic orange laser on top of the Roborock S5 that swivels around and allows the robot to tell where it is in the room.
If your robot is reading "Error 1: Laser Distance Sensor" there is a good chance you may need to replace the motor that drives the laser. For additional information, check on the Roborock S5 Troubleshooting page.
Before you begin, power off your robot vacuum.
你所需要的
Power down your Roborock S5.
Place it on a flat work surface with the power buttons facing toward you.
Use an opening tool to carefully pry under the section of the top panel with the buttons.
Gently pull upward to snap the panel off the top of the vacuum. It is secured in place by five snaps that you will need to release to remove the panel.
另外一个人完成了本指南。
