简介
Use this guide to remove or replace a broken rear camera glass in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
你所需要的
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5等其他人完成本指南。
一条评论
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
